FETS. In high power applications, usually MOSFETs.
FET = Field Effect Transistor. MOSFET is one kind of FET, the “metal oxide semiconductor” kind.
If tonight between 2AM and 3AM you don’t know what to do, check it out. They are quite impressive, since they don’t amplify current like their BJT brothers, but only need a voltage to switch them on. They do however have capacitance on the gate, so you have to hit them hard (literally one or two ampere for a split second) to turn them on hard.
They don’t have a constant voltage drop (BJT is usually around 0.6V to 0.7V constant, which makes them unsuitable for high current low-voltage applications these days), and if you spec it right they have low forward resistance, but… unlike a BJT, they conduct in reverse, so in order to have directional control you need to put two in series.
And usually just one isn’t enough for the current levels of a battery, so you will usually have a bank of them
But generally, if you ask about directional charge/discharge blocking using FETs, battery makers should know what you are on about.
We would probably be able to add it for you, but we would need the protocol documents of the battery/bms, and also a little piece of source code that shows how to talk to the bms. If source code is not available, we can work from the protocol documents, but then it takes MUCH longer, as we would need a battery to test with, figure out the protocol document and write code bit by bit until all the functions of the bms is done, whereas a little source code (regardless of what language) is a much quicker development cycle.
At the MOMENT, testing to still confirm this, it appears that the first BMS I so much like, has a LOT of ticks.
Must Have Specifications:AP20S003 - and it comes in a nice metal box …
No - Separate Charge/Discharge FET’s / Relay to keep the functions separate
tick - Bluetooth to connect to Xiaoxiang App, i.e. Venus integration
tick - RS485 port
tick - RS485 and UART must be able to work simultaneously
tick - Balancing current >100mA
Good to Have:
tick - 20 cell connection with BMS max 72v, i.e. 24v and 48v banks and 17/18 cell bank
tick - 150-250amps capability, to not “stress” the BMS
Nice to Have:
no - Active Balancing - can add a separate active balancer if need be, as it is right now, can balance when charging and discharging already, at least, it seems like it does that.
no - Parallel connection of BMS’s
I’m now finding out which Jaibaida BMS’s models do have separate charge/discharge FET’s / Relays, as it is “hidden” in all the translated English.
So far, methinks, this model BMS could be a winner.
Just note that the Americans do like their 12V (I think it is all those campers), so that JBD is a 12V version.
Mine looks the same but is the 15S 48V model.
Few balancers are active, and those that are cost a premium. You use that expensive balancer once (when the battery is new) and then once in a blue moon (after a large discharge)… and the rest of the time it does nothing.
It does not use the Xiaoxiang App, but I have the Voltage, Current and Power working already in the driver.
Then it does not do parallel that I know.
The rest it can all do.
I don’t like either of those.
How about 8542.31?
Electronic integrated circuits:
8542.31 - - Processors and controllers, whether or not combined with
memories, converters, logic circuits, amplifiers, clock and timing
circuits, or other circuits
I don’t know, but this would probably work. There seems to be a few codes for bars depending on what they are made of. A lot of them attract a tariff.
But, I suppose “battery parts” 8507.90 would work. I doubt you’ll be hanged for it, if you’re wrong.
