Good day, all.
Please assist with a problem I have with my 4 yr old Axpert / Mercer Inverter. The fans used to stop during the night on low loads. With loads as low as 150Watts the fans are still running. Any suggestions or info I can share?
Good day, all.
Sounds like the intake filter/vents are blocked - if it has, use a vacuum cleaner or remove and wash them.
When I had my Mecer I inverted the fans. From the factory they pull air from top to bottom, which is not what hot air wants to do. By removing the 4 screws on the fans and rotating them to push air up, they almost never ran anymore. Try it
I did the same - made a big difference!
