So I live in a relatively small complex, 39 units. Currently have a mecer trolley type inverter with lead batteries that were replaced last year ( both inverter and battery) as the previous one had its days. I wanted lithium but there was no stock and since the cctv. Intercom, fence runs off this, I couldn’t be without it for too long.
The current power draw is around 200-300 watts when batteries are not charging.
Now there’s a centurion d10 gate motor that is also going through batteries every 1.5 to 2 months due to loadshedding.
I want to add some panels to be able to charge the batteries and then possibly connect the gate batteries to the trolley batteries as well. In future, will replace the existing batteries with new lithiums.
So questions:
Is it better to just remove the 2 12v 7A batteries in the gate motor and connect directly to the inverter batteries or leave the 2 batteries in the gate as well.
What’s the best option for an mppt /charge controller to charge the batteries. For the gate motor, centurion offer what looks like an Epsolar pwm charge controller which charges an external battery and the the gate motor batteries are then connected to the load output of the charge controller.
If I use a tiny victron mppt, what else do I need to get it work.
Anyone have experience with thr victron pwn charge controllers and is there much difference compared to the other Chinese ones we get locally.
Any better way to do this without replacing everything.
