Is there a simpler way to change the AC charge current on the Multiplus II than to download the config file, edit and upload again?
I used the Limit Charge Current setting under DVCC before my panels went up.
Haven’t used it since the panels went up and I don’t think it is an AC limit alone, but did the trick for me when I only had batteries.
In my case I want to have unlimited charging current from my SmartSolar and AC coupled Fronius Primo, but grid charging should be restricted to a trickle, e.g. 10A.
I’m currently using Node-RED to adjust the DVCC charge current limit depending on the solar yield, but it would be great if that wasn’t necessary.
