Hi Guys
I’ve moved house where I previously had a Victron inverter which was so easy to work on and understand, the new house is 3 phase and has 3 x Luxpower 5kw inverters with Hubble batteries, I’ve noticed that the canbus cables are installed with trunking but have all been pulled out and the settings are for lead acid, I’d imagine there must have been some sort of compatibility issue which hopefully I can get resolved at a later stage with someone who knows the Luxpower products well.
Even with this massive setup the guy was still spending R4K per month, I’ve changed the geyser times to rather come on during peak PV production (they were coming on middle of the night and early morning
But what I want to do in the meantime until I’ve sorted the settings out is drop the battery SOC from 60% to around 30-40%, its not clear from the interface where to do this and I don’t want to screw things up, could someone perhaps let me know where I can set this please?
Thanks.
