We have some 19.2V battery packs that we don’t use. We got them for an application, but the project was scrapped.
The specs of the packs are as follows:
Total capacity: 614WH
Cells:
4000mah 3.2v IFR26650 (LifePo4 cells)
Total of 48 cells per pack.
Ive open 2 of the packs, and with a bit of cell re-arranging, and spot wield, they can be converted to either
1x 192A 3.2V cell or
12v 48a battery pack. Only add a BMS.
Price on them is R650 each.
Some of the packs might have been in use for a couple of times, but most of the packs have 30 or less cycles on them. The cells is rated for 2000 cycles before 80%.
Interested, Could you share some pictures if you have.
Anyone on here tried some spot welders out in the past, i see quite a few local to buy from cheap to not so cheap.
