Have you seen this?
[Firmwareupdate for US2000C, 3000C | EFFEKTA Regeltechnik GmbH] (Firmwareupdate for US2000C, 3000C | EFFEKTA Regeltechnik GmbH)/
Have you seen this?
Hi Jaco,
I note this post is a bit dated, but hopefully you can still advise:
I have 8 x US2000 (2020 models) but decided to reduce the stack and connect some of it to 4 x UP5000 batteries I have bough recently. However the UP5000 does not communicate with the US2000 . Do you perhaps have access to the latest firmware for the US2000’s that would enable these batteries to communicate?
I don’t think they are compatible for the UP2500
good day
I have a frozen bootloader on a PYLONTECH US2000 plus
can I ask you to send me the magic software,
and firmware updates
thank you
my email: fj0905736248@gmail.com
Hi Jaco,
I have a LV-hub that got stuck while update from 1.6 to 1.8. I thinks it’s bricked, does the software also help with a LV-hub? Do you have any suggestions? If yes, could you send it to niels@lithiumaccus.nl
We are an official Victron install company in the Netherlands.
Thank you very much
Niels
amigo me pode enviar tenho pylontech bloqueda romaxx2010@gmail.com
obrigado
friend can you send me I have pylontech block romaxx2010@gmail.com
thanks
Hi,
I’m in the same situation. After update with firmware US_C_V2.8_Crc.bin one battery don’t work. Is briked!!
I read this forum and a possibility to solve with a tool mentioned form @Pylontech-Jeff.
Please can help me!
Thank you in advance
The old FW was:
Soft versione V1.8
Release date: 22-10-19
Barcode: Y221125C30021127
Hi,
I have a new US2000C battery (with a new chip) and the firmware installed is v2.2.
I knew the latest was v1.8 but probably Pylontech has released a new firmware.
Since I want to align all my batteries, do you have more information and where I can download this firmware?
Thanks
Hi,
I have also Aton Inverter. I’m able to see the SOC value of all battery.
Inside connect choose United and then your numbers of battery.
The soc appear on the right side on bottom menù
Good morning
I’m Giuseppe from Italy.
A technician yesterday installed a new firmware on my US2000C battery and now the battery is blocked.
The update stopped at 83%,
The battery does not turn on anymore!
I’m sorry and angry.
Can someone help me?
Please send me the “Magic File” software that restores Pylontech batteries after the block.
I would be really very very grateful.
My email is [redacted]
@JacoDeJongh is the expert on this, but he’s running around quite a lot these days so I don’t know when he’ll be able to help.
I removed your email address so that spambots and marketers don’t pick up on it, but moderators can still see the content of the old post.
Hi Jeff,
sorry, I couldn’t find another way to write to you.
I unfortunately shot one of my US2000C batteries with a faulty firmware update. I heard about you on a German forum and you have helped many people get their battery back in working condition.
I can send you pictures of the serial number etc. if you contact me. My mail address is thomas[dot]loebig[at]gmail.com.
I would be very grateful for your help.
Best regards
Thomas
Hallo Jeff, I tried To Update Mythen Pylontech US 2000 C, that Crashs my System every few weeks when Running lower than 20 %. The Update stopped at 83%, now it is dead and not connectable. I want to use Force upgrade tool. Can you help me. Serial: H22D015C32241183.
Ulrich Graefe, Berlin, Germany.
Posting here in frustration … I have a Pylontech Force H1 battery that my Goodwe GW6000-EH activated hybrid inverter will not fully communicate with and I would like to update the firmware. The battery BMS is showing no firmware installed, or version 0, and so is the inverter. I have had little/no luck in getting firmware from Pylontech.
The Goodwe inverter signals that there is communication with the battery, and it is showing some data such as SOC, battery health, temperature. Logging into the Goodwe inverter, I can select Pylontech Force H1 from a menu as the attached battery, but when I make that selection, nothing happens.
I can log into the Force H1 BMS over WiFi with my laptop and there is a page where I can upload a firmware Zip file, but I haven’t been able to get anything out of Pylontech.
Can someone supply working firmware for the Force H1?
Many thanks
…looks familiar - 3 out of 4 us2000 school of 2018/9 in my bank bloated that way with one leaking fluid [thats why i hang my batts and dont stack them] - put it in a safe place and start warranty claim…
regards
g
Hi, I can’t find the firmware. Where did you download it from?
