I removed my Carlo and it did help with the prepaid meter trips, but I also removed the oven as it was only on the Carlo side. Trips do still happen but much much less often.
What we must not lose sight of, the limitting of the inverter based on main breakers max amps.
Must say, Iâm learning.
Still prefer the Carlo route, donât want the main DB fed via from AC_Out2, even if it is in bypass.
âDaai goed bly sommer maar net daar, die goed is wat ek oor worryâ type of feeling.
True, but I think it is a minor point.
Remember, flipping your bypass switch would still put everything on Eskom, the way it was.
But to each his own - For me a massive advantage of getting a Victron (or most true hybrids) was the transfer ability so that you donât need to worry about your circuits while Eskom is up. 50A (in most cases 70A because you will have at least battery available and you REALLY shouldnât be drawing 50A+ continuously on a 63A breaker, youâll too often trip the power) is ample.
Mine is set up with the Carlo, but Iâd have preferred to go the route that I deem is simpler (i.e. minus the Carlo - Less reliance on a external device).
