Freedom won eTowers cell balancing
What are the chances to get a pro-rata refund, and start over?
I have suggested it but recieved no feedback yet.
I would not do that… They are swollen for a reason.
That’s exactly what I told them. If they want me to do so I insist they take full responsibility for any damages caused by this battery should it worsen. But I would prefer not to even accept delivery for the battery. I’ve still got Herholdt’s loan battery so if Herholdt’s want their battery back they must sort it out with FW. i will not let them close a ticket on a battery with swollen cells after all the hassles I had with these batteries in the last 10 months.
Geez, I quickly googled: why do lifepo4 cells swell
Ag nee man, FW can go and jump.
Not good to hear this. A bad batch is a bad batch. Do the right thing and replace.
I hope my batch is good. Been having them for around 2 years now and all bought within a 12 month period. So far so good with no issues.
Sooooo. I’ve got the battery back with a RMA report from Freedom Won stating that they’ve replaced the cells, balanced and tested the battery and are happy to return it to me. First thing I noticed when the courier guy dropped it off (yes the courier costs to send and return the batteries in this whole series of events already costs me close to R4k) was the packaging. I sent the battery in the new box that the new, replacement battery came in, the box it retruned in was this old beaten up box that was held together only by packaging tape. But hey! at least I’ve got my battery back.
I immediately went home, installed it, changed all nescessary setting from 200Ah to 300Ah and set the system to “keep batteries charged” to balance the 3 eTowers. The one that came was on 100%SOC and the other 2 on 94% so not that much of a difference. It took about an half an hour before none of the batteries accepted any more charge current so I set it back to Optimized (With batterylife)
The repaired battery’s firmware was still on V1.10 while the newer ones are on V5.07 but hey, if FW’s technicians says it should work, it should work, right?
Next morning… repaired battery 68% SOC and the other two 47% & 49%. Delta voltage on the 2 newer batteries also back to above 30mV where it was 2-3mV without the older firmware battery connected.
I am so fedup with this batteries you won’t believe it. I’m going to report it AGAIN and then just leave it be, not returning the loan battery until issues are sorted 100%. Worst mistake of my life trusting a South African brand name with my investment only to find China made products that’s been rebranded. And yes! the sticker on these batteries clearly states “Made in China”
Hope you came right. I’ve just logged for the repair of one of my batteries. Looks like a dying cell. The one is dropping down to 2.75v while the pack has 18% charge.
Almost any battery you buy will have Chinese cells and probably a Chinese BMS. In the case of local brands they do the assembly and the QC. So you clearly have grounds for complaint on the service front here, but if you disqualify any brand that has Chinese components, you will have a very short list of options.
My batteries are doing okayish. Cell balancing is good with max 0.05V Delta on all batteries but I still have the issue with SOC% differences which irritates the crap out of me. In my opinion max 5% difference in SOC% between batteries is acceptable but up to 20%?? Let me also add that the batteries is charged to 100% SOC daily and used with Victron ESS, Optimized with batterylife. The SOC% discreppancies seems to be okay according to FW but according to my own homework, it’s not normal. :man_shrugging:
FreedomWon doesnt assemble the ETowers locally. They made in China and shipped down complete.
Actually looking that the battery logs they may have been built in Hell according to the temps they logged during manufacture.
Ah. I know they don’t have the same BMS as the LiTE range, but I didn’t know they were completely imported.
Could it be because the temp sensor connected was open circuit at the time?
Not quite that bad, but cells got up to 49c.
Soooooo. I started getting “high cell voltage” errors on one of my eTowers again for about 10 days now. Have gone through the process of balancing all batteries again but everytime the “high voltage cell” is battery 3 cell# 7. The other cells are constant at 3.35ish Volts but that one keeps spiking to 3.55ish, at which point it throws an error on the VRM notifier. Still doing diagnostics so sure if this is going to start a war with FW again. This one has done just over 300 cycles. I’ve brought down the DVCC max charging voltage to 55.6V and not 55.8V like thay state in their manual but that cell still spikes at 3.55V. Haven’t checked for swollen cells or anyting like last time. Only done a quick diagnostic to start the balancing procedure. Will need to get authorization from FW again to open up and charge the cells individually like they instructed last time if the problem does not correct itself…Which it probably won’t
I can update this after my talk with FreedomWon, from June/July eTowers are going to be manufactured locally. They also going to be using 200AH cells going forward which should sort out some of the balancing issues. Not sure if this means that they will be incompatible with the 100AH eTowers.
My one battery has been booked in, they confirmed that cell 8 is damaged when performing remote diagnostics When I removed it, it I noticed the case it bulging, couldn’t see it when it was stacked. Battery is 4 years old so lets hope no funny games with the warranty repair. Shipping was R750 via courier guy.
The other thing that support brought up is that they will trade in batteries for people looking to upgrade, no idea what they will pay but will try ask.
Same thing that happened to mine. When I took the stack apart to change the sequence of the batteries I saw that one was swollen so badly that the casing was bent outwards. They appaerently tested it and wanted to return it and let me keep using it with the swollen cells but I refused without them giving me a written acknowledgement that they would be responsible for any resultant damage should anything go wrong with the battery. They then replaced some cells and returned the battery to me. I still had the same issue with SOC% discrepancies between the 3 batteries and found my capacity to defninitely have decreased. I barely have 10kwh of actuall use in the 15kwh bank when I drain them to 20%. I even tried to sell them to get rid of it and start a DIY bank but they seems to be worth nothing used. I wonder what they would trade them in for? I paid R25k each for mine 3 years ago. I’m sure I’m not even going to get R15k for all three now.
If having no luck, why not strip the battery down, and make your own DIY with the existing good cells and a better BMS?
I was thinking the same. I think there might be enough space in the casing to jam 200Ah cells in. They’re still going at the moment and time is not laying around here. I will keep that project for a later time. First I need to get the new panels on my roof and connected.
But this is sad hey? You invest in batteries to have at least 6-8 years of hasslefree energy storage and then after only 2 year, 300 cycles, you start having sh@t with your R75k investment. I know of systems running with old 2v Pb cells that’s been going non-stop for 15 years. Is Lithium really the way to go then? Less maintenance, sure. But all the time I’ve spend diagnosing batteries or even just sitting with FW technicians on the phone while they’re logged in on your batteries, I could’ve re-filled my old PB bank 100’s of times in that same time. It’s debatable. Hopefully they get their sh@t together and get their eTowers sorted. They work good…when they work…
