Limiting charge rate is to prevent charging from the utility if ESS is below the set level due to blackouts discharging the packs. When utility comes back, it will charge the banks. I prefer solar to do that. So then I rate limit the charge until battery charge level is above the ESS set %. My solar can charge em fast enough, bout 170A worth.
