I burn around 5%/h when the house is idling with no large loads. So I set an extra 10% reserve in SoD when levels 1-3, and 20% extra for levels 4+. ESS auto-recharge will save my skin if it drops too low below the set SoC so ill be good enough for morning to ride it out.
That being said ESS with battery life has been keeping my battery around 40-50% as the panels are struggling during winter. This aggressive load shedding has caused me to also make a lot of tweaks to my system.
I’m only seeing the cold front from Thursday… really hope it doesn’t start earlier…
And we should be back to stage 2 before midnight, and therefore only getting shedded by 08:00 tomorrow morning. Anyways! It is too complicated staying up to date with these variable levels. I just set my min SoC to 50%. At stage 6 we get 4 hours. At worst, assuming I’m at min SoC and zero sun, I use 5% an hour (at worst). So that gives me 10% of safety margin (at worst).
So I’ve used the “set it and forget it” strategy. And I maybe pay one unit of electricity oer day for it. Maybe.
Same here. When we hit stage 4 or higher, I set “Keep Batteries Charged” and then, because all the large loads are bunched up in fewer hours anyway (eg pool pump, geysers, etc), I don’t lose that much due to full batteries anyway. What is lost is an acceptable cost for the luxury.
I use home assistant with solcast solar forecast which is far more accurate than built-in forecast for cloudy days. Based on the solar forecast, the DoD is set at 8PM and again every update between midnight and 6AM.
This means, that generally, battery is only used over night if the next day is full sunshine. For in-between, the DoD is set according to what I expect to be able to recharge the next day after baseload and load used solar first.
With this, I generally just dont have to worry at all about morning loadsheds. It may sound like I dont save as much from not using grid as others, but I do after tweaking it a lot. It is just delayed. Savings is ± the same.
I also have the forecast on my dashboard, like so:
I did it this way, so that I could create the forecast graph as you can see in the above screenshot. It allows me to extract more data into entities than is available using the different solcast integrations I tested.
I have been using: https://loadshedding.eskom.co.za/LoadShedding/GetStatus and so far pretty accurate. It only updates when the LS stage changes so you can’t use it to forecast.
Finally got it working with Node Red and I can now set my Min SOC to a level based on Stage which is working perfectly. Or manually overide if needed (using a Telegram integration).
Not that I need it anymore, but I finally figured out how to get the correct CoCT loadshedding stage into HA.
Attributes even include when the next stage and what stage that will be. Eg. for today, CoCT is mostly on stage2 until 10pm at which time it goes to stage3. The history on the sensor is wrong, because it used to be a template that was hardcoded, but I now found the CoCT loadshedding app’s endpoint.
Ok I created it into a HACS addon for those that want it.
Add it as a custom repository to HACS and you will be able to install it.
After adding it under integrations, then go back and configure your area, to enable the “next loadshedding slot”.
The only part that needs to be fixed, is to take into account the next stage change, which it currently doesn’t, but that should fix the issue for those that want that ability in HA.
