Lots to unpack here.
Think of frequency as a system thing.
As @plonkster says think of voltage as a local thing.
(This isn’t strictly true all the time, but it is the best way to picture things).
System frequency is tied into power generation and the control centres try to match load and generation very closely to 50hz. (This is a power matching thing).
There are many things ( eg. motors, transformers) that get designed to work specifically at that frequency.
System faults can manifest as sudden load upsetting that fine balance with a momentary frequency dip, but then the protection will disconnect the faulty part of the network and hopefully a minimum amount of load and the net effect will be minimal. This is because the system tends towards stability because it has a lot of mechanical inertia to ride through the blips.
Within a very tight bandwidth, the national control centre actually has the tiniest bit of play.
It’s been 30 years since I toured South Africa’s national control centre at Simmerpan. (At that time national security was very high and tours weren’t just a thing).
I was quite surprised to see why frequency was tweaked within that very tight bandwidth.
Extremely technical devices were used to adjust the system frequency throughout the entire country.
The controllers had two clocks on the wall, an AC one and a DC one. With the tiniest of adjustments, the aim was to have both clocks reading the same time at the end of the year.
They reset the clocks every year. I remember being told that they had lost two minutes the previous year.
What also has been touched on in this thread, is flywheels and mechanical momentum.
Yes, it is a very important consideration, especially when considering generation by things like inverters.
Electronic generation doesn’t have mechanical momentum like a heavy spinning armature.
And by that, I mean electronic generation has none, nada, nothing, not some.
Even wind generation, although they use heavy turbines, once their inverters break the chain any mechanical momentum is lost.
DC power lines also break the chain.
Motors on the other hand will also contribute a bit of mechanical momentum.
Part and parcel of having that frequency stability are that heavy things take time to speed up and slow down.
As @Richard_Mackay says that brick wall effect is needed for system stability.
Frequency swing is not a binary event, it swings up beyond the 50hz target and back below it, over and under until it gradual settles. Like a pendulum gradually settling at its nadir.
Too far over and under and things start to trip at both high and low frequency, exaggerating the swing, making it more and more unstable until the entire system is lost.
I hope I am getting across that too far away from 50Hz will be uncontrollable and catastrophic.
(When generation cannot balance the load, frequency instability is a threat without load-shedding.
This is also why if ZA ever lost the system, it would probably take months of a precarious load/generation balancing act to put it back together after a black start. I know that load-shedding is a PITA, but the alternative would be far worse. It’s akin to a doctor performing an amputation to save a life).
So the ratio of generation with momentum and generation without momentum becomes important.
Too much electronic generation and there is insufficient inertia to keep the frequency stable.
(By the way, this is another little technicality Mr Yelland doesn’t allude to).
@TheTerribleTriplet There are already devices that add mechanical momentum like flywheels. These are called synchronous compensators. Essentially, these are synchronous machines that are neither run as generators or as motors.
They are only supplied with sufficient power to spin themselves, they in turn don’t work as motors. By altering the DC excitation they are used for power factor correction because the wattless power can be varied. Although nowadays, pf correction is also being done by static ( read electronic) devices.
So ESKOM’s big generators ( also synchronous machines) are probably actually needed as a spinning reserve ( ala electrical flywheels) even if the generation is not required if ZA is to go renewable at a high percentage
So when all is said and done, there is a bit more to things than Mr Yelland would have you believe.
