agree… I’m just trying to figure out what modes address the 2 MPPT’s would be sitting on.
G
G
did you try going into venus gx and then settings/services/“modbus/tcp”/available services?
There you should have different unit id’s for each MPPT so that you can read values
done,
I see unit Id’s of 245 and 243. will try and add them in and see thanks
G
… am I correct in assuming the unit id on Venus interface is the address in the yaml.
G
Unit ID is the slave parameter in modbus.yaml
CCGX-Modbus-TCP-register-list-2.70.xlsx (48.8 KB)
C212… This this is a typo, should be 3724
Not that me probing the address is yielding any value currently anyhow…
G
Ignore… seems this modus sheet might be old/out of date also. switching to the newer 2.70.
G
Very nice! When I reinstall HA (soonish) I will use this. I don’t have a Victron inverter; but I can get the same values, current, charge %, amps, ec, etc and have sensors in HA for those already. So should be able to connect it to this sensor template
Thanks!
