So very rapidly I have 11 smart devices that I am ultimately controlling with Google Home. This includes my TVs, or probably the Chromecast devices that we have attached to them (Google Home knows about these).
So I have five CBI smart controllers. These are registered on the CBI app (I presume in their cloud).
I have two controllers for water isolators, no-name brand devices that I bought from GeeWiz. These are registered on SmartLife, as are the two CBI smart adaptors (basically plug in timers) that I recently got.
I use Google Home to tie every thing together.
This is at least one app too many. I want to consolidate everything.
Note that CBI do not prevent their devices being used with SmartLife. The two ASAs were never linked to the CBI smart app, I took them out of the box, plugged them in and SmartLife found them.
Now I would like to start moving those ASCs over to SmartLife. In fact SmartLife can do all the automations that I use Google Home for. Since I have no interest in including the TVs or chromecasts in automations, I don’t need to use Google Home.
Today I tried to move one of the ASCs from the CBI app to SmartLife. This didn’t work. Removing it from the CBI app is easy enough. Now neither CBI nor Google Home can control that device. But adding it to SmartLife didn’t work.
I added it back to the CBI app, noting what I did, then deleted it again. Confident that I knew how to get the ASC into pairing mode I did this then scanned for new devices with SmartLife.
Nothing.
So in the end I added it back to CBI, and relinking my CBI app to Google Home put it under control of Google too.
Some notes
- the CBI app looks a lot like SmartLife, but on SmartLife I can scan for whatever is in pairing mode (this worked for the ASAs), whereas in CBI I have to specify the type of device I am adding.
- You can do a manual add in SmartLife (and see point 1, I think this is what you really do in CBI), but you have to specify the type of device and there’s nothing really like an ASC.
- Just scanning for a device in pairing mode was good enough for the ASAs (which don’t seem to work quite the same as ASCs in turns of their interaction with the network). It also worked for the controllers that I bought for the isolators in my my water lines. But it doesn’t seem to work for ASCs.
- I reset the ASC I tried to move. But when I eventually reconnected it to CBI again it was like it was never away - all the stats were there, the device got it’s old name back. I’m guessing that this is not because that data is stored on the ASC, but because CBI recognised the MAC address.
This is not the end of the world. Not yet. But in the new year I want to get some smart light switches installed. My electrician has done this before but they are not CBI devices. So IDK, do I now need ANOTHER app on my phone? Can I link that app into SmartLife? I’m guessing that SmartLife will do the job, but I don’t know.
In any event, getting everything controlled by SmartLife is first prize for me. I can do all the same automations that I can do with Google (maybe more), and it’s one app on the phone rather than three (and counting).
Is it possible to bring those ASCs into SmartLife after linking them to CBI? See one of my earlier remarks - I don’t think CBI are trying to block their devices from being used with another app.
